Is the Contacts panel, you can change the order of the fields?
Has thanked: 1281 times
Been thanked: 895 times
Re: Is the Contacts panel, you can change the order of the fields?
You can drag&drop columns to change their order. Hope that's what you were looking for. Thanks.
