Is there the possibility to automatically delete "past" appointments in the calendar in EssentialPIM PRO 10.0.2 for Windows 10? If yes, how do you do it?
Thank You!
Denis
Automatically delete past appointments
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Automatically delete past appointments
So far this is only possible By using EPIM DupeRemover (https://www.essentialpim.com/features/f ... dupremover).
Thanks I also need to knowadmin wrote: ↑Mon Jan 03, 2022 1:01 pm So far this is only possible By using EPIM DupeRemover (https://www.essentialpim.com/features/f ... dupremover).
