issues installing v10.0
gertone
Post by gertone »
Installing the latest EssPIM I was told that I needed a PRO license to access the server (which I do have BTW)
Now it seems something messed up the DB
Code: Select all
Exception log with detailed tech info. Generated on 15/12/2021 15:28.
 Application title: EssentialPIM Pro
 Application file: C:\00_software\80_administrative\EssentialPIM Pro\EssentialPIM.exe
 Application: EssentialPIM Pro 10.0  14/12/2021
Exception message: unsuccessful metadata update
STORE RDB$FIELDS failed
attempt to store duplicate value (visible to active transactions) in unique index "RDB$INDEX_2"
Problematic key value is ("RDB$FIELD_NAME" = 'DIDITEMINT').
Exception address: 00778B28
Main thread ID = 12952
Exception thread ID = 12952
Object Logs:
15:28:29.738  DBOpen
15:24:52.498  DBOpen
15:28:30.168  MainForm
15:28:29.319  ConnectDialog OKBtn
15:28:26.961  ConnectDialog GroupBox1 LoginCB
15:28:25.800  ConnectDialog FileCB
15:28:21.742  ConnectDialog ServerCB
15:25:01.423  MainForm
15:24:59.416  ExceptionDialog DetailsBtn
15:24:54.342  ExceptionDialog OkBtn
15:24:53.476  MainForm
15:24:51.304  StatusForm
Memory: 16263; free 10765
PrevExceptions:
15:25:01.178  unsuccessful metadata update
Updates: 1
Last update: 15/12/2021
I hope you can help
Has thanked: 1412 times
Been thanked: 984 times
Re: issues installing v10.0
Please make a copy of your DB, delete all the data from it and forward to us. We'll be able to quickly fix the issue then. Thanks!
gertone
Post by gertone »
Hi Max, thanks for your reply
could you please expand on how to
copy the DB and remove all data from it?
note this is a server license, so I have a windows server with a DB server and an epim db file, but I access this (connect) from a windows client
- my personal login tells me to connect to SYSDBA on the server
- the issue happens when I try to do exactly that
Can you physically get access to the database file? If so, please create a copy of it (right click - copy), then paste it into another folder on your local PC. Open the database file locally with EPIM 9.x, then going from one module to another - select all -> delete, after that make sure to optimize the DB in File->Database Management and when this is done, forward it to me via PM here in the forum (or share the download link). Thanks!
gertone
Post by gertone »
I assume I need v9 for that... essentialy meaning I have to reinstall. It does not work with v10
gertone
Post by gertone »
Before I go installing and older Essential PIM.
Is there an other option
eg.
access Firebird directly through SQuirreL with SYSDBA credentials
run a sql update (the one I assume you would be running on my empty database)
wil make a backup of the database file (I can get to it, no problem)
This seems a whole lot more convenient
Another option would be to wait a bit till we release a fix. I think it's going to happen today.
gertone
Post by gertone »
That my friend would be the option I prefer most ;-)
Thanks a lot for that
gertone
Post by gertone »
Fixed with the new release, thank you
