Multiple Calenders
Multiple Calenders
Up until this latest update, I was able to right click on the Epim Icon pinned to the Taskbar, Windows 10, and open a 2nd calendar. Then cut and paste across them. Very helpful and quick. As of today after the install I can no longer open the second calendar up. Is there another process to allow me to achieve the same results?
Re: Multiple Calenders
Maybe just coincidence? This fixed it. Hope it helps someone else.
Fix: Can't Right Click on Windows 10's Taskbar Icons
Press Ctrl + Shift + Esc to open up Task Manager. · In Task Manager, locate the Windows Explorer process, right-click on it and choose Restart.
