errore collegamento Database
StudioMELISSANO
Post by StudioMELISSANO »
Buona sera
ho comprato una seconda licenza e ho cercato di collegarmi ad Data Base sul server ma mi restituisce il seguente errore
unavailable database
potreste dirmi come lo posso superare?
Grazie e buon lavoro
Has thanked: 1411 times
Been thanked: 984 times
Re: errore collegamento Database
Most likely path to the database file is wrong. Please see here how to set it up correctly:
https://www.essentialpim.com/help/conne ... verhhh.htm
Matteo_Minghetti
Post by Matteo_Minghetti »
Ho lo stesso tipo di problema.
In aggiunta a questo, dal client, quando faccio un nuovo database e cerco di salvarlo nel server, mi compare qusto errore:
unavailable database.
Exception log with detailed tech info. Generated on 25/07/2022 10:13.
Application title: temp.3EEE0206.epim - EssentialPIM Pro
Application: EssentialPIM Pro 11.0.2 21/07/2022
Exception message: unavailable database.
Exception address: 00778F18
Main thread ID = 4856
Exception thread ID = 4856
Object Logs:
10:13:31.422 DBSave OK
10:13:31.402 DBSave
10:13:06.102 DBOpen OK
10:13:05.850 SetViewMode OK
10:13:05.735 SetViewMode 0
10:13:05.390 DBOpen
10:12:55.595 DBOpen
10:13:31.552 MainForm FormPan TBXToolbar2 TopTB NewItemBtn
10:12:55.989 MainForm
Memory: 32665; free 25353
Updates: 1
Last update: 25/07/2022
Please describe the problems in as much details as possible, so that could reproduce them. Thanks.
Matteo_Minghetti
the database server is on "SERVER001"
in picture n°2, you can see the adress of database file - server side.
This adress is:
Server001\SERVER MINGHETTI\EPIM_DATABASE
On client side, the adress of database file on server is:
Y:\EPIM_DATABASE\temp.73488236.epim
as you can see in picture n°'3
Afetr openng EPim on client i do this:
File - Connect to server
and then i fill like pictures 004,
then i return "unavailable database",
as shown in pictoure 005
The Y drive seems to be network, not the local one? The EPIM database file needs to be located locally on the server. Thanks!
Matteo_Minghetti
What do you mean? Of course Server Is on the network. The y drive Is of course not on my PC, but in a server that i share with other users....otherwise how can i share the database?
Is the "Y" drive local one and physically (not via network) attached to SERVER001?
Matteo_Minghetti
i changed with F: letter of server, now it works
