I noticed that when I look at most of my tables, the auto-word-wrap doesn't appear to be working any more?
Not sure if this was the last update? Anyway, if this does happen to you then you can easily correct it - do the following;
1. Go to the View Menu (in notes)
2. Click on World Wrapping (Or press CTRL-W)
All your tables should now be back to normal and not 500 screens wide
![Smile :)](./images/smilies/icon_smile.gif)
Cheers
Xine
