EssentialPIM Pro bug 表格突然丢失
中文语言的讨论和支持
wljwar
Post by wljwar »
EssentialPIM表格突然丢失.mp4
(4.08 MiB) Downloaded 909 times
时不时也会出现乱码!!!这软件我用了十年了,笔记乱码的问题一直没有解决。
购买的正版
Re: EssentialPIM Pro bug 表格突然丢失
I'm not sure what the problem is. Could you please explain it in more details?
wljwar
Post by wljwar »
Please watch the video I sent carefully, which records in detail the process that the form suddenly disappears during the use of essential PIM
You mean the borders around some of the items in the bulleted list?
wljwar
Post by wljwar »
Yes, that's a single row and single column table created. It will be lost
Thanks, will attempt to fix that in the next release version.
Meanwhile, as a workaround you can set the cell spacing option larger than 0 and in this case cells will not disappear upon saving.
