Calendar and Tasks
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: Calendar and Tasks
This will happen automatically.
- Has thanked: 21 times
- Been thanked: 28 times
I recently found a Box to chk that Shows the Rt Column Tasks List in the -- Mail Module -- Too.
Can't find it anywhere in Options.
HOW did I accomplish That?
FYI, I use to Rt Clk on a Calendar date / Add Task and See it Immediately in the Date Box AND Rt Column Tasks at Completion. THAT changed = No Task seen in Rt Column.
Went to Task Module / Add to Root method BUT have discovered that the Original Way Does Show ONLY AFTER I Close EPIM and re-open it.
Mystery Solved for that one.
EPIM PRO LIFE - v12.2 - Win 10 Pro - 22H2 --- ESET EIS Prem - Mbam Prem - Diskeeper Pro '15 - Macrium Pd vX
- Has thanked: 28 times
- Been thanked: 6 times
I found out that my problem was not EPIM. I placed my database inside a encrypted drive and it is slowing down EPIM database so much that everything was just taking long to show up. Tasks and appointments on the calendar were just taking a long time to show and disapearing when i changed the view.
I probably never noticed because i was using my SSD and now i had to change to a normal hardisk.
Interesting point, thanks for the update.
