The context menu which opens when right clicking an anchor has no option "Remove Anchor".
Perhaps it could be added? In the same way as it exists in the context menu of Hyperlinks:
"Remove Anchor" added to the context menu
Re: "Remove Anchor" added to the context menu
Ok, noted, thanks for the suggestion.
