Your request can't be completed. A default task folder can't be deleted
- Has thanked: 1 time
Hello, it looks like I have deleted a task folder in Epim but when synchronizing it in outlook, it refuses to delete that folder which it's considered as default.
I looked at the logs but there is no indication of what outlook expects to find (the folde name).
Any ideas ho to solve this?
Thnak you
Thnak you
Re: Your request can't be completed. A default task folder can't be deleted
Yes, please forward me the log file, will check out what's wrong.
Hello Admin, thank you so much.
I have attached the latest outlook sync log
- OutlookComSync_2021_03_08_19_20_41.zip
- (7.97 KiB) Downloaded 242 times
Thanks for the log! Please click on File->Database Mangement, then select Outlook.com under the "Clear synchronization data" section and click on the Clear button. That should help.
