EPIM 9.7 (and 9.10 too!) doesn't show anymore alarm for "Appointment/Task reminder(s)"
scotchgav
Re: EPIM 9.7 doesn't show anymore alarm for "Appointment/Task reminder(s)"
Post by scotchgav »
I have exactly the same problem after upgrading 9.6 to 9.7 (EPIM Pro Portable in Windows). I used EPIM Synchronizer to copy to a new database and reminders worked for a while, but have now stopped working again. Existing reminders can be snoozed successfully, but editing an existing one or adding a new one doesn't work
Has thanked: 1412 times
Been thanked: 984 times
haegok, what's your EPIM edition a Free or a Pro one?
scotchgav, please get the new EPIM Pro Portable build here: www.essentialpim.com/download/temp/Esse ... roPort.zip, unpack it into the EPIM's directory and replace the executable file with the one found in the archive. Would that help? Thanks!
haegok
Has thanked: 8 times
Post by haegok »
hello admin,
my EPIM edition is Pro 9.7.
scotchgav
Post by scotchgav »
The new EPIM Pro Portable build from admin in post at Tue Mar 02, 2021 7:53 pm fixed the problem for me - thanks!
haegok
Post by haegok »
thanks for your note, unfortunately that doesn't help as I use the epim for windows (desktop version).
haegok
Post by haegok »
admin wrote: Tue Mar 02, 2021 9:51 am haegok, what's your EPIM edition a Free or a Pro one?
my edition is EPIM Pro.
ablamis23
Has thanked: 6 times
Post by ablamis23 »
haegok wrote: Mon Mar 01, 2021 9:16 pm I got exactly the same problem with EPIM 9.7 as well. I followed the advice of admin and dismissed the legacy alarms at once. After that the reminders came up as usual. This was yesterday. Today the problem is back.
Same for me. Followed all instruction. Need again the previous version or a fix asap.
Thank you.
PS: Just realized, that this topic is in the Free version. I have that problem in the paid version!
Ok, good, thanks for the updates, a fixed version will be officially released soon.
ablamis23
Post by ablamis23 »
Thanks for the update. The reminders seems to work.
Great, thanks for the confirmation!
haegok
Post by haegok »
I wanted to see whether the reminders would still work overnight. Everything is fine now.
Many thanks!
Excellent, appreciate the confirmation!
Markinson
Has thanked: 4 times
Been thanked: 6 times
Re: EPIM 9.7 (and 9.10 too!) doesn't show anymore alarm for "Appointment/Task reminder(s)"
Post by Markinson »
The problem rises up with new 9.10 version, too ... :(
---EDIT to add ---
This time, unfortunately, synchronizing doesn't solve ...
"Facesti come quei che va di notte, che porta il lume dietro e sé non giova, ma dopo sé fa le persone dotte"
Dante (Purgatorio, Canto XXII)
Please update to the 9.10.1 version, that should fix it.
