Cannot set private appointment not visible to other user
Trinitylab
Has thanked: 16 times
Been thanked: 41 times
Post by Trinitylab »
EPIM PRO, Win 8.1 x64, 9.6.1
I created user A and user B, both have standard full access to all users data.
A creates a private appt in a Calendar, however it is seen by user B.
How to set this in order not to show in user B selected appts?
Re: Cannot set private appointment not visible to other user
If a user has access to all data then it has access to everything in the database.
Trinitylab
Thank you for the reply.
Could you tell me how to make it work, ie. how to set up users:
one DB,
two users, none of them would be sysdba,
occasionally, each of them has to have the option to have a full access to each other's appointments, in case to change something, put a new one,
some of the appointments don't have to be visible by each of these users, like they are only for one person, and the other does not have to see them in the calendar.
I would be grateful for any hints.
Cheers,
Piotr
Why not use the common SYSDBA login in such occasional cases?
Trinitylab
Surely, but that involves relogging. If it is twice, thrice per day, it is simply inconvenient.
If you wish to make some data visible couple of times per day only, re-logging is still less of inconvenience than any other options (which involves altering data permissions) we could possibly think of.
Trinitylab
Thank you, understood.
