Solved. Bug: Contacts > not sustained custom colors of grid lines
Trinitylab
Has thanked: 17 times
Been thanked: 43 times
Post by Trinitylab »
Hello, epim biz pro 9.5.2, win 10 and 8.1 x64 both.
Tools > Options > General > Appearance > Grid lines color
if set to custom, is not saved. When reopened, nothing. Actually it does not sustain even the horizontal and vertical grid lines turned on in View submenu.
Win 10 Pro 64x
Re: Bug: Contacts > not sustained custom colors of grid lines
Unable to reproduce. These options are stored in the INI file, please check if you have write access to it.
Trinitylab
I know what happened.
3 DB opened in 3 instances.
I have changed the settings (custom bla bla) in one of them, and I have closed this one before the other ones (without changed settings).
So logically, the last closed instance's setting was saved in INI.
Win 10 Pro 64x
Re: Solved. Bug: Contacts > not sustained custom colors of grid lines
Got it, thanks for the update.
