Hi support team,
I am running EssentialPIM Pro 9.1 on Windows 10 (Version 2004). Whenever I send an email with an PDF attachment to another computer, the attachment cannot be opend. I always get the error message, "Adobe Acrobat cannot open the file, the file type could not be recognised or the file might be damaged".
What I can do is save the PDF file to the computer but you still cannot open it, since the filesize is 0 kb.....!!??
(Btw: PDF files recieved from other sources are not any problem at all, they open just fine without any problems).
So what is the problem here?
I searched the forum but didn't found any thread regarding this particular problem.
I noticed this issue about 3 months ago and I am pretty shure it worked before....
I would appreciate any help on this matter.
Thanks in advance,
kind regards,
Christian
PDF attachment sent with EssentialPIM won't open - file size 0 kb
- Been thanked: 1 time
- Has thanked: 1079 times
- Been thanked: 743 times
Re: PDF attachment sent with EssentialPIM won't open - file size 0 kb
It seems this particular issue was present in the 9.1 version of EPIM, please update to the latest one 9.5 and it should be gone for good. Thanks!
Ok, great, skipped some of the updates.
It works perfectly fine with version 9.5.2, no more issues!
Thanks a lot!
Kind regards,
Christian
Thanks a lot!
Kind regards,
Christian
Hi support team,
running EssentialPim Pro Portable (9.7) I encounter the same problem:
when trying to open a PDF (or other, e.g. JPG...) file, I get an error message
C:\program fles\EPIM\Temp\ ... file does not exist
but when I save that file to some local folder, I can access/open it with no problems (from there).
Seems like the [file name]-parameter passed internally to the "open [program] ..." - command is different from the one passed to the "copy ..." or "save ..." -command.
Or did I make some fault in my configuration ?
Thanks in advance
kind regards
carsten [moosbrugger]
Thanks in advance
kind regards
Please post a screenshot with the error message here.
