Notification of tasks not working in IOS
- Has thanked: 1412 times
Re: Notification of tasks not working in IOS
So all notifications created on the iPhone work and the problem is only with some of the tasks that get synced form WinEPIM?
No, it is the same problem with tasks created on phone. The last (main-sub-subsub) task raises the notification, notifications from parent tasks are ignored.
Ok, thanks, will see what we can do here.
Task alerts on IPhone still not working, whether created on IPhone or in EPim, whether parent task or sub-task.
I am using EssentialPIM Pro and IPhone XS Max
Thanks,
Steve
Thanks,
Steve
Previously there was a problem with tasks created on an iPhone, not with those synced from WinEPIM. You say reminders don't work in any case for you? If so, please check if you allowed all permissions for the app. Thanks.
Again, no task notifications are working! Wether old or new database, or main or sub tasks.
Additionally, if a calendar appointment from a repeated appointment is deleted in WinEPIM, this specific appointment is not deleted on IPhone after sync.
