Problem description:
I just want to report a bug with the spanish version of the software. In the attached screenshot the program´s behavior is inverted regarding the 2 possible choices (yes or no). In other words, when the program says that perhaps you are missing an attachment and asks if you need to attach it; if you answer NO the email is not sent and stays in editing mode. If you answer YES, it sends the email without giving you chance to attach it.
Bug Report
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Bug Report
Thanks, it seems the initial English phrase:
Looks like you forgot to add an attachment to the email. Should we still send it?
wasn't properly translated. Would appreciate if you tell us how to correct the Spanish phrase so that it sounds right.
- Allekz
- Has thanked: 8 times
- Been thanked: 16 times
Re: Bug Report
Looks like you forgot to add an attachment to the email. Should we still send it? =
Parece que olvidaste añadir un anexo a este mensaje. ¿Quieres enviarlo aún así?
