Solved. Bug, important: one db cannot connect to server, asking for license
Trinitylab
Has thanked: 16 times
Been thanked: 41 times
Post by Trinitylab »
EPIM 9.2
Win 10 guest connecting to Win 8.1 host, both x64.
Strange:
on Win 10 I have two instances running.
From one I can connect to DB1 via server.
From the other I am trying to connect to DB2, which worked fine for years, and I get the message:
It does not make any sense. If I don't have the license, I could not connect to DB1.
Anyway, cannot work.
Trinitylab
Re: Bug, important: one db cannot connect to server, asking for license
Looks like only one DB triggers that bug, say DB2.
I opened DB3 and it works smoothly.
Trinitylab
Does anybody have a clue what that might be?
Trinitylab
@admin, would you have a look at the problem?
What I can add is it did not exist before 9.x
Has thanked: 1411 times
Been thanked: 984 times
My first step would be to sync the DB2 into the new one using EPIM Sync. Will it help?
Trinitylab
Works! Thank you!
How do you think, would it be reasonable to do the same with every other db we have, just to "refresh" them?
Re: Solved. Bug, important: one db cannot connect to server, asking for license
Awesome, thanks for the confirmation!
I wouldn't recommend doing anything with the DB if it's working normally. As EPIM employs some internal DB checking/optimization mechanisms on a regular basis anyway. That particular issue was related to a fix we introduced some time ago and which seemingly didn't apply to the DB2 correctly.
Trinitylab
OK, thank you, got it.
Trinitylab
Hello, it's the same, now I can see two users in DB, however there is only one connected.
Will do the sync as above, which is workaround, but the problem persists.
Please copy-paste the "This database was opened in" values from File->Database Management. Thanks!
Trinitylab
Hello admin.
The workaround worked, this is this new DB, synced earlier (as above) to new,
Opened in:
9.3, 9.0
but it was used, gosh, since 5.x some.
In this case the problem shouldn't have happened.. If you still have the previous database, please delete all the data from it, leaving just users with their rights intact and forward to us, will check it out. Thanks!
Trinitylab
It persists.
I have noticed that this might be something with Firebird. (?)
Simply, when DB on the guest PC is closed in an irregular way (lost wi-fi connection or similar), then 2 users are still shown on the host PC using that DB. No way to kill one of them. Looks like Firebird does not see that the other PC is disconnected.
Will check that out, thanks for the update.
Firebird uses a standard TCP/IP connection, which is considered to be broken only after 2 hours by default system settings. That's a bit too much. Attached is the reg file that changes this setting to 5 mins, run it and it should fix the problem with ghost users in the database.
KeepAlive.reg
(288 Bytes) Downloaded 201 times
