Thank you. To be run on the host, I presume?admin wrote: ↑Mon Dec 14, 2020 2:00 pm Firebird uses a standard TCP/IP connection, which is considered to be broken only after 2 hours by default system settings. That's a bit too much. Attached is the reg file that changes this setting to 5 mins, run it and it should fix the problem with ghost users in the database.
Solved. Bug, important: one db cannot connect to server, asking for license
- Has thanked: 16 times
- Been thanked: 41 times
Re: Solved. Bug, important: one db cannot connect to server, asking for license
- Has thanked: 1419 times
On the server. That setting tells Firebird whether there's still a connection or not.
Thank you, done, will let you know if worked.
So far so good.
I did a test: hard break, plugged off the network cable from the guest. 30 sec. later on the host: still two users. 4 minutes later, only one.
Seems to work.
Shame it took so long to solve it. The problem persisted since at least 5.x
Seems to work.
Thanks for the confirmation. This isn't really related to EPIM, rather to the system TCP/IP configuration.
