Win 8.1 x64 and Win 10 x64, EPIM 9, bug exists since some 8.x
Passwords
Copy a full record,
Paste,
Modify the new entry, sequence of modifying the fields: top-bottom, but using this view at the bottom, not opening the separate window;
1. field, Title, press Enter - the field in the main view is updated;
2. field, I call it Login, update, press Enter - the field in the main view is NOT updated, stays the same.
Workaround: in order to update the field Login, one needs to move up along the fields, using ARROWS.
Previously, Enter worked fine.
See the pic, and where the active field (blue) is, after pressing Enter nothing has changed up there, still Login 1 in both records:
Bug: fields in Passwords do not update if the record is copied, and modified
- Has thanked: 16 times
- Been thanked: 40 times
