Synchronizace mezi Android tabletem a mobilem
Nápady a připomínky k EssentialPIM (CZ/SK)
Moderator: Georgo2010
dnjl
Post by dnjl »
Dobry den. Mam zakoupenou a nainstalovanou PRO verzi ePIM android app v.5.7.3. Chtel bych ji pouzivat na tabletu (samsung s2) nebo mobilu (samsung s8), no synchronizace mezi temito pristroji nefunguje korektne. Kdyz napr. na tabletu vytvorim novy ukol, tak na mobilu se objevi jenom nazev ukolu, obsah ukolu je prázdny. V kalendari se ukoly zobrazuji duplicitne. Dekuji za reseni.
Re: Synchronizace mezi Android tabletem a mobilem
Hello, how do you sync the devices with each other? Via WinEPIM?
dnjl
Post by dnjl »
Hello. I do not have installed winEPIM. I only have android apps installed on tablet and mobile.
How do you sync the devices then, through Google?
dnjl
Post by dnjl »
I already have been installed winEPIM. Now it's sync ok.
