Synchroniser un calendrier externe
Moderator: daprod
Re: Synchroniser un calendrier externe
you can set up synchronization with Google and Google data will be available in EPIM.
try to delete the synchronisation and set it up again.
Seems like authentification is not set up correctly. Please set the synchronisation again and make sure you correctly go through the wizard.
