copy/paste table rows in notes editor not possible
bitseeker
Post by bitseeker »
Hi team,
it´s not possible to copy/paste row(s) in a table in the notes editor.
Would be great if you made this work.
thx bitseeker
EPIM Pro v8.5
Win10 Pro x64
Re: copy/paste table rows in notes editor not possible
Suggestion noted, thank you!
swwhit52
Post by swwhit52 »
This is probably the same as bitseeker's post, but copying and pasting a row puts all of the columns from the copied row into the first column of the new row. Example: After sorting (nice feature, by the way), my column header row moved to the bottom as expected. When I highlighted all the cells in the bottom row and pasted into a new row at the top, it performed as described above.
A workaround is to copy and paste the value from each cell individually but this can be cumbersome if there are many columns, or if many rows must be copied (or cut) and pasted.
Has thanked: 1412 times
Been thanked: 984 times
swwhit52, please make a short video demonstrating the problem, so that we're 100% sure we fully understand your request. Thanks!
swwhit52
Post by swwhit52 »
I'm afraid I don't have time to make videos. My request is not worded very well but I was trying to keep it short.
You can easily duplicate the problem by copying a row in a table that has values in the cells and pasting the row to a new location in the same table.
If it works correctly, then I must be doing something wrong.
thank you.
DG
Beta Team
Has thanked: 16 times
Been thanked: 33 times
Post by DG »
Attached is a video of the problem swwhit52 described. All of the copied cells are put into the first column.
Video_EPIM_copy-paste_table_rows.wmv
(381.06 KiB) Downloaded 62 times
Thanks for the video, DG, clear now. Will see what we can do here.
