If you are not a logged in member, PLEASE READ.
ikkyu
Beta Team
Post by ikkyu »
Please be aware that this is the place to discuss (and submit) iCals, but not the one to download them from. If this was what you wanted, go to
http://www.essentialpim.com/?r=download&pr=ical instead.
Also, if you're not logged in as a member, you will not see the upload window and will not - understandably - know what is going on. It might be very confusing.
Sorry about that!
glenn59
Has thanked: 37 times
Been thanked: 15 times
Re: If you are not a logged in member, PLEASE READ.
Post by glenn59 »
Clicked on the link above while logged in, but didn't see any ICAL info.
EPIM Android Pro v6.0.17 -Samsung A52-5G - Android OS v14
EPIM Portable Pro V6.0 RC2
EPIM Desktop Pro V8.64 - Windows 10
This was a very old topic, as you can see. You can google for iCal and import them into EPIM.
glenn59
Post by glenn59 »
Thanks Max. Have had some success with holidays. Sure beats manually entering them!
