How to quickly open two DBs in EPIM to work simult.?
- Has thanked: 17 times
- Been thanked: 43 times
EPIM 7.65, Pro Net Biz.
We need to work on 2 DBs opened via Firebird server simultaneously.
I have a workaround how to do it, but this is inconvenient.
Is there any option from EPIM inside?
If not, then it would be fantastic to have an option "Open DB in new window" or - even better! - "Open new window". As then new, empty EPIM windows opens, and I can use "last opened files", and quickly open via a server.
Cheers,
Piotr
Cheers,
Piotr
Win 10 Pro 64x
Win 10 Pro 64x
Re: How to quickly open two DBs in EPIM to work simult.?
what prevents you from doing this is not 100% clear to me, but, generally, you can open several instances of EPIM Business (client), and each might have opened a separate database via single Firebird server.
Just make sure in Tools-> Options-> Allow only 1 copy of EssentialPIM at a time... is unchecked.
Dear Max,
Thanks for the reply, nothing prevents. It is just inconvenient:
MainDB is working,
I want to open SalesDB, so
RMB on EPIM shortcut in Taskbar in Windows,
click on the last used SalesDB, which is pinned to the top,
it opens, but as from the file, not from localhost,
click again to close the message about shortcuts in use,
I close all SalesDB,
I have now empty EPIM window/instance,
so from drop-down File menu I can now select the same SalesDB, but this time I can open it from
localhost and so on...
The same has to be done on the second, guest PC.
Everything would be much easier if there is an option in
File > New > EPIM window/instance.
MainDB is working,
Win 10 Pro 64x
Win 10 Pro 64x
I see, thanks. We had suggestion in the past that would allow to use path to database in EPIM shortcut. Therefore, you could place 2 shortcuts to EPIM on the Desktop, each would open own database. The problem is, this solution would be used only by a handful of users (who would also need to read manual)
Max, how to do this, using EPIM server?Max wrote: Thu May 17, 2018 9:10 pm I see, thanks. We had suggestion in the past that would allow to use path to database in EPIM shortcut. Therefore, you could place 2 shortcuts to EPIM on the Desktop, each would open own database. The problem is, this solution would be used only by a handful of users (who would also need to read manual)
Win 10 Pro 64x
Win 10 Pro 64x
Currently there is no way to do this, it requires development efforts from our side.
Hi Max,
The solution would be very simple, just add the option in Main Menu, File>
open EPIM's another instance;
and please add more "lately used files" in the list in Menu > File, not only three. That would help a lot, and it is very easy and simple to implement.
Win 10 Pro 64x
Win 10 Pro 64x
Much needed.
It would be much better just to add 5-7 lately used files.
Or the option to open new instance.
Win 10 Pro 64x
Win 10 Pro 64x
- Has thanked: 21 times
- Been thanked: 184 times
i had a similiar thing.
1) my own local DB
--> shortcut to my personal EPIM DB. opened with my "epim pro portable"
2) my companie DB in network
--> used a copied directory of "epim pro portable". I linked the .exe file
3) from time to time direct editing through the admin PC in the network, was a remote session (e.g. teamviewer).
I've tried a second network instance, but i failed. So solution was the remote session
1) my own local DB
*including RC`s
*including RC`s
Hi guys, just reminding, adding "open new instance" would solve everything here.
Win 10 Pro 64x
Win 10 Pro 64x
