Cannot add a new item any more
Hi there,
something strange is going on with my EPIM. Since today I am not able to add new days and tasks any more. The tab is opening but I cannot click it. When I click on the tab nothing happens. I cannot access it. Attached a screenshot.
Can you tell my what my cause this problem? I have restarted my pc several times - also updated to the latest Version of EPIM - nothing helps.
Best regards,
kweb
Best regards,
kweb
Re: Cannot add a new item any more
Well kinda strange. Its just working when I right-click to the tab and choose "maximize". Then I can add a new entry. But its not working in window mode.....
considering other clients do not have the issue, I would tend to think it is related to your Windows setup. You can also try re-installing EPIM.
