EPIM Notes: Import of a Table
a8907433
Been thanked: 170 times
Post by a8907433 »
I use on my mobile the app Money Wise pro to keep track of my expenses. Money Wise can export to .csv, .xls, .pdf and .HTML. Now I want to have this data in Notes in EPIM (Windows). And now I see- There is no way to import the data of a table into EPIM notes!!! Only .txt and .rtf.....
Please improve this!!!
Re: EPIM Notes: Import of a Table
thank you, suggestion noted. However, EPIM is not a spreadsheet program, thus do not expect it to import csv/xls. We may consider PDF/HTML for the future.
Shaun
Has thanked: 4 times
Post by Shaun »
Hallo EPim
I'm just giving this suggestion a nudge, because I have exactly the same requirement.
I've got a text note in EPim, for home network, with 4 columns.
MacAddress EquipmentName IPAddress LocationOrNotes
At the moment these are just tab separated, which make updates a bit cumbersome. I would like to have a more flexible format, so I can manage these entries, sort, select etc.
I'm not looking for this management in EPim, but I would like the ability to export my text or table ( complete , no selection is necessary ) to csv, and then to import from the same format and data back into EPim to replace / update my MacAddress list.
Thanks again, Shaun
Thank you, that's noted.
shanu010
Post by shanu010 »
Hello Epim.
I would also suggest the same. Please do consider. Would be great to have the ability to import a table as template in notes. So that we can take fast and organized notes. Meanwhile what I do is, add an excel file as attachment. Would be awesome if we could not do it in one place. Anyway it is a much appreciated software.
Thanks a lot.
ecsaltz
Has thanked: 30 times
Been thanked: 77 times
Post by ecsaltz »
Shaun wrote: Sun Apr 05, 2020 4:05 pm Hallo EPim
Thanks again, Shaun
I keep almost the same data in Excel, but duplicate it in EPIM, then sync with Android EPIM. Many times I am at a client, on a ladder working on IT equipment, and need access to data - and there it is, right on my cell phone that is with me on that ladder. Please consider some type of import capabilities soon - thanks for listening.
Has thanked: 1411 times
Been thanked: 984 times
Sure, will do, thanks!
Shaun
Post by Shaun »
Hallo EPim
Another nudge for this enhancement. I have a collection of Excel format files ( simple text data, no formulae ) which I would like to combine in to a single place.
I can manually convert .xlsx to .csv format.
Then I would like to import.csv to EPim table, and later the opposite export EPim table to .csv format file.
I can then manually edit / update / convert the .csv or .xlsx file as nescessary ( And repeat import )
Thanks again, Shaun
