reminder sound
reminder sound
I found by reading in the forum, that EPIM team changed the behaviour of the reminder settings in the way, that by default no sound will be played, because a number of users suggested for it.
I do not agree, in fact, when first time using this function, I thought, there is something not working correctly.
Of course I see, that you cannot change the behaviour of the app, everytime after someone has argued for that. So I make the following suggestion:
Give in options the posibility to either determine the default setting the user likes and additionally the possibility, that EPIM automatically changes as default setting to the option, you just used in the dialog. So you can switch the default behaviour very quickly (using the last above mentioned setting) or you change only for the just edited task und stay with your normal setting as default (if you use the individual settings in options). Doing this would all users allow to easily make his/her own choice and all can be happy.
Bye
Thomas
Bye
Thomas
