activating Pro
norsea
Re: activating Pro
Post by norsea »
I get error message when trying to upgrade that says:
"Error
You already own this item."
OK
And that's all folks.
I cannot sync which makes it worthless.
Yes, rebooted already, more than once.
What to do???
Re: activating Pro
You're resurrecting a topic that's 7 years old. Would you mind elaborating more about the problem and providing us with a couple of screenshots about it, please?
norsea
Re: activating Pro
Post by norsea »
admin wrote: Mon Feb 06, 2023 8:23 pm You're resurrecting a topic that's 7 years old. Would you mind elaborating more about the problem and providing us with a couple of screenshots about it, please?
What I wrote on the post I made is exactly what is on the screen; hence the use of the quotes!
norsea
Re: activating Pro
Post by norsea »
I continue to await are response please.
I cannot activate my EpiM Pro on my tablet due to the above error.
What am I to do if you just ignore me???
Re: activating Pro
Would appreciate if you answer my questions above. Also, having the Pro version or not shouldn't influence your ability to synchronize in any way.
