Passwords
Passwords
I use EssentialPIM Pro Portable 5.57 on a Windows 7 machine and EssentialPIM Pro 3.0.2 on an Android tablet. The passwords on the Android tablet are password protected and I have forgotten the password. I can access all the passwords on the Windows version without any problem, but without the password I cannot access them on the tablet. Is there any way to reset the password in the Android version of the program?
Thanks,
Mark
Thanks,
Mark
Re: Passwords
Unfortunately it's not possible to reset the password on Android without knowing it (security measure). What you can do is to clear data of the whole app (in this case all the modules will be empty on Android, including passwords) and then sync it with your Windows version of EPIM. Just make sure you clear up the Android sync data in Windows EPIM, as well (click on file->database management, select Android from the drop down list and click on Clear).
- Has thanked: 17 times
- Been thanked: 43 times
Re: Passwords
Hello admin,admin wrote: Mon Mar 10, 2014 9:21 am Unfortunately it's not possible to reset the password on Android without knowing it (security measure). What you can do is to clear data of the whole app (in this case all the modules will be empty on Android, including passwords) and then sync it with your Windows version of EPIM. Just make sure you clear up the Android sync data in Windows EPIM, as well (click on file->database management, select Android from the drop down list and click on Clear).
Best in the New Year!
Is this still the only option to clear the data?
Anyway, I am trying to do it, but get the request to provide the password to the Passwords module.
Seems not logic. How to clear the data from the Passwords module?
Win 10 Pro 64x
Win 10 Pro 64x
Re: Passwords
Thanks! You can uninstall and then reinstall the app, for instance. Although, all data will be lost then.
Asking for password is a security measure.
Re: Passwords
OK, did it, eventually worked out.
The idea to reset master password to Passwords:
could be sending email to the indicated previously address. Or to the address which is a Google account from which one bought EPIM Android.
I understand texting is not the option, so email would work fine.
Win 10 Pro 64x
Win 10 Pro 64x
Re: Passwords
Yep, it seems we need to include this feature. Thanks!
Cloud password?
Would like to know if the password for the cloud sync can be reset? Thank you in advance!
Looking forward to all the enhancements that will coming our way in 2023! Keep up the good guys!
Tinpusher, Lifetime Member!!!
Re: Passwords
You can change your password by logging into your account on the web: cloud.essentialpim.com. Thanks.
