serious sync problem for Chinese in win7 64
中文语言的讨论和支持
sansi
Post by sansi »
After I updated to the latest version and bought a lifetime key,
1,When I try to sync FROM pc TO usb driver (portable edition), it can't been done as below:
Sometimes "9I" is shown as "-9" or "9?"
2,I tried sync BETWEEN pc AND usb, it can finish, but usb edition does not show the characters correctly as below:
the last word was replace by small black blocks and strange characters.
and even more
3,It seems many Chinese characters are replaced by "�" which is a black block with a "?" inside.
Hope to help Solve this.
Re: serious sync problem for Chinese in win7 64
thank you for posting screenshots.
Can we get a sample of the database BEFORE synchronization?
So that we could try to reproduce the problem. You can send it to ma@essentialpim...
sansi
Post by sansi »
Max wrote:Hello,
UPDATE:
I found maybe the problem is not SYNC but ENCRYPTION. This is what happened:
1,this is original information:
2,this is setting up password and Encryption:
3,this is what happened after Encryption (with red marks):
Noted that it happens at: 1, the last character; 2, when there are Chinese characters and English or even numbers in same sentence.
sansi
Post by sansi »
An email with database was sent to epimsupport@essentialpim.com.
