EPIM Pro Portable升级到5.5后,日历输入中文事项保存报错
Re: EPIM Pro Portable升级到5.5后,日历输入中文事项保存报错
Please post screenshots demonstrating the problem. Very hard to understand.
Exception log with detailed tech info. Generated on 8/3/2013 16:56:56.
Application title: TEST.EPIM - EssentialPIM Pro Portable
Application file: F:\EssentialPIMProPort5\EssentialPIM.exe
Application: EssentialPIM Pro Portable 5.5
Exception class: EXMLException
Exception message: Tag </div> not found
Text: <div> 人民?/div>
</font>
</bod.
Exception address: 00B482EB
Main thread ID = 3568
Exception thread ID = 3568
Object Logs:
1343069718 TTask Change 237056767820164735
1342251328 TTask Change 255123894888422356
1342241406 TTask Change 258051209471604279
1342241406 TTask Change 228385389353138168
1342241406 TTask Change 259246845969223185
1342241406 TTask Change 236693653880710850
1343086812 ExceptionDialog TextMemo
1343070281 TaskDialog PageControl1 TaskTS GroupBox1 TitleEd RichViewEdit
1343067281 MainForm FormPan FormPan2 TasksForm DayViewDP
1343065281 AboutForm OKBtn
1342252281 MainForm FormPan FormPan2 TasksForm DayViewDP
1342240750 MainForm
1342237281 PassDialog GroupBox1 PasswordEd
1342236281 StatusForm
1342235531 MainForm
Call stack for main thread
Stack list, generated 8/3/2013 16:56:56
(0000D514) [7C92E514]
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Memory: 2038; free 1000
Display : 1440x900 pixels, 32 bpp
</font>
</bod.
Object Logs:
1342240750 MainForm
1342235531 MainForm
报错界面
PS:输入少于5个汉字,并未报错,但字符多于4个汉字,报错
具体错误代码,和楼上基本一致
- 3.jpg (14.26 KiB) Viewed 9595 times
We have just released 5.51, which should fix the problem. Tell us it it does not work:
http://www.essentialpim.com/get-epim
升级到5.51,主题栏中可以用中文了,但是备注栏中输入中文保持,仍然报错无法保存!
Exception log with detailed tech info. Generated on 12/3/2013 13:16.
Text: <div>保持中文任然报错?/div>
</font>
Main thread ID = 632
Exception thread ID = 632
Object Logs:
1675284625 AppMinimize OK
1675284593 DBSave OK
1675284515 DBSave
1675284515 AppMinimize
1675059578 TTask Change 242097974220162547
1675059046 TTask Store 238143944785912587
1675058812 TTask Change 238143944785912587
1675015625 TTask Change 238143944785912587
1674898546 TTask Change 238143944785912587
1674887437 TTask Change 266647328122066176
1674887437 TTask Change 285113524186379737
1675428578 ExceptionDialog TextMemo
1675421890 TaskDialog OKBtn
1675408890 ExceptionDialog DetailsMemo
1675400890 ExceptionDialog DetailsBtn
1675398890 ExceptionDialog OkBtn
1675398218 ExceptionDialog TextMemo
1675284890 TaskDialog PageControl1 TaskTS GroupBox1 TextMem RichViewEdit
1675214890 MainForm FormPan FormPan2 TasksForm DayViewDP
1675184890 TaskDialog PageControl1 TaskTS GroupBox1 TextMem RichViewEdit
1675183890 TaskDialog PageControl1 TaskTS GroupBox1 TitleEd RichViewEdit
Exception stack
Stack list, generated 12/3/2013 13:15
Stack list, generated 12/3/2013 13:16
Memory: 2038; free 1057
</font>
Object Logs:
1675284515 DBSave
Exception stack
