Please check before posting or you post may be ignored.
Re: Сontact Sync Questions EPIM Android 5.1 B1 & EPIM Pro 7.51 (windows)
I suspect those 3rd-party uninstallers did not delete EPIM.ini file previously.
PeCe
Has thanked: 101 times
Been thanked: 329 times
Re: Please check before posting or you post may be ignored.
Post by PeCe »
Great to hear that it seems to be solved. I hope you can confirm this after the weekend, because than I guess it is really finally solved. :)
lezp
Post by lezp »
Yes, it really is behaving perfectly. I repeat my thanks to you and to Max for your patien t help.
Sincerely
Lezp
