<RUSSIAN> updated
<RUSSIAN> updated
Hello.
I've updated Russian.lng, now it has almost every string translated.
It's a pity, but not everything is dislayed well becuse of lack of screen space.
Anyway it might be used.
- Russian.zip
- Russian translation
- (5.24 KiB) Downloaded 1734 times
- Has thanked: 1532 times
- Been thanked: 1049 times
Thanks for the file, Andrew!
Try to be creative - shorten or rename those strings which do not fit. Русский - богатый язык!
Andrew, я извиняюсь, только что вспомнил, что у нас уже есть более новая версия файла на сайте - http://www.essentialpim.com/index.php?r ... &pr=lfiles.
- Moderator
- Has thanked: 30 times
- Been thanked: 61 times
Well, I've tried to translate EPIM 1.7 version to have all data in Russian. Maybe it could be useful to somebody here.
Just need to check all hotkeys, but actually I prefer mouse.
- Russian.zip
- (7.39 KiB) Downloaded 1666 times
vvorl, thanks. I'd suggest you to have a look at the new 1.8 Beta 1 version too
- Moderator
Well, finally I realized that I shouldn't be a beta tester to get 1.8 Beta (boy, aren't I smart ?! )
Ok, here is Russian translation of 1.8 Beta Pro Portable. I believe, it's the same as Desktop version. At least it works with my 1.7 Portable Free version as well.
It has differences with 1.7 version I had posted earlier, because I tried to make all data visible on buttons, menus etc. So, some of them are shorter now (but some still doesn't fit, unfortunately).
Any suggestions and comments are appreciated.
- Russian.zip
- (8.35 KiB) Downloaded 1665 times
vvorl, thanks! Please let me know if you need a key for the Pro version.. so to say to test your translation
- Moderator
here is russian translation for version 1.8 RC1. There are also some minor changes in existing messages.
Просьба к пользователям русской локализации высказывать любые замечания или пожелания. Заранее благодарен.
- Russian18rc1.zip
- (8.44 KiB) Downloaded 1591 times
