Email subject line
Email subject line
Is there any way I can stop Epim from saving the email subject line ?
And is there anyway I can delete the ones that have already been saved as the option from the drop down list does not work ?
Thanks,
Del.
Thanks,
Del.
Re: Email subject line
search your computer for EPIM.ini file, close EPIM and find:
"[MailSubject]" section in the ini. You can delete some data from there, but preserve the numeration.
Currently there is no way to stop EPIM from saving it.
Thanks Max, that removed the existing entries, I guess I'll just have to repeat the procedure every so often.
What happens if I reduce the numeration, will it reduce the number of saved entries ?at the moment it's 1 to 13.
Del.
Del.
