EPIM calendar export
I like to export calendar / synchronize with Google/Outlook. I have some task visible in my calendar. But I can't export them from the calendar. Any solution?
- PeCe
- Has thanked: 101 times
- Been thanked: 344 times
Re: EPIM calendar export
Have you tried the menu options [file] - [export] - [ToDo] and than select Ical or CSV ?
As I see it Outlook should be able to import both file formats.
Google I do not know, but guess that at least CSV also should be possible to import.
With the export you have choices to export all ToDo's in all tabs, all ToDo's in the present tab or all selected ToDo's.
EPIM 12.1.2 Pro portable / Android EPIM 6.0.17
