12.2 / size column width to optimum
- Has thanked: 17 times
- Been thanked: 43 times
Re: 12.2 / size column width to optimum
Where exactly is this option? In each column RMB menu?DG wrote: Wed May 07, 2025 4:36 pm I upgraded to v12.2.1 build 1042 with the option to disable dynamic column sizing. I have disabled it and this has resolved the trouble I was having with columns randomly resizing. Thank you.
Regards,
DG
Win 10 Pro 64x
Win 10 Pro 64x
Thank you, I knew that and asked because it simply doesn't work, so thought there is another setting.DG wrote: Wed May 07, 2025 6:16 pm In each module where you can display items in columns, right-click on a column header to see the new option.
I have it turned on, and still cannot work, have to manually set the width.
Win 10 Pro 64x
Win 10 Pro 64x
After the update to 12.2.1 it doesn't work in one DB.admin wrote: Tue May 06, 2025 9:04 pm The update is being rolled out in stages, as usual. You can either wait for it to reach you automatically or you can visit the download page, manually download the latest version and install it over your current one.
Win 10 Pro 64x
Win 10 Pro 64x
- Has thanked: 13 times
- Been thanked: 44 times
With 12.2.1 / build 1042, the new option to prevent column resizing seems to work on my side.
Thanks to support/developement unit for making this possible and to make tables usable again.
Hopefully no problems will occur again, as to this, because this has been a very frustrating "feature".
check 12.2.1 / build 1042
i see soon too
i see soon too
Helps Make EPIM Great/No1!
Now at last, with 12.2.1 the automatic adjustment of the column width is a thing of the past. We now have an “almost” full view of our data again.
Only the double-click on the right edge of the column header no longer sets the optimum width but reduces the column width so that the content is no longer readable - see video.
It's amazing what a feature like the automatic adjustment of the column width can cause as a consequence and thus reverse the effect.
Oh ....... doubleclick no longer sets optimum!!!
Didnot realise.
That is an important feature ... please let this still be possible!
Didnot realise.
It appears the issue is limited to the Category column. All other columns should be functioning normally.
