EPIM - Dark Theme
Has thanked: 1569 times
Been thanked: 1070 times
Re: EPIM - Dark Theme
This one should work: viewtopic.php?f=1&t=34494. Thanks!
kk
Has thanked: 30 times
Been thanked: 15 times
Post by kk »
Love the new dark theme!!
dirmansyah
Post by dirmansyah »
EPIM 9.1 Portable
Dark Theme
In Week Agenda view, the dates of appointments are too dim. It is hard to see them.
You mean start times?
dirmansyah
Sorry.
Yes, I mean the start-time and the end-time.
Also, the system icons, which are in light gray, are hard to see. I must turn my screen brightness up to the level I almost never set.
It seems to me you guys are very fond of light-gray colour. Why is it so?
admin wrote: Wed Jul 01, 2020 3:04 pm You mean start times?
Could you please post a screenshot here indicating which icons you mean?
VictorParkerPIM
Has thanked: 9 times
Been thanked: 65 times
Post by VictorParkerPIM »
People my age have trouble seeing the dim light gray charters.
I think most people under 50 wouldn't have a problem.
Please make all charters darker.
dirmansyah
admin wrote: Fri Jul 03, 2020 1:10 pm Could you please post a screenshot here indicating which icons you mean?
VictorParkerPIM, which chars you mean, could you please specify or better yet attach a screenshot demonstrating that?
dirmansyah, is that from the 9.1.1 version? As situation should be improved in it.
VictorParkerPIM
This is the worst place.
download/file.php?mode=view&id=12718
Win10 Pro Ver. 2004 (OS Build 19041.329) 64-bit, 32GB Ram, 4K Monitor, EPIM Pro Life 9.1.1
You mean highlighting of the active icons?
dirmansyah
admin wrote: Sat Jul 04, 2020 12:44 pm dirmansyah, is that from the 9.1.1 version? As situation should be improved in it.
dirmansyah, thanks, will make another attempt in the next update.
VictorParkerPIM
The Icons are so dim and small you can hardly see them.
High res. monitor set as recommended.
Most other programs look OK.
VictorParkerPIM, you might choose to go back to the previous set of icons in Tools->Options->Appearance, check if you like them better.
