11.7.3: Differences in tags
- Has thanked: 31 times
- Been thanked: 13 times
Re: 11.7.3: Differences in tags
No, I always checked the mails first, then the Explorer.
I have just checked it again:
- Checked in the task manager whether instances are running -> No
- Opened Epim -> Tags Explorer -> Everything visible
- Email modules -> right click on a mail -> Tags -> 18/30 tags visible.
Are you sure you're using the suggested build from a couple of posts back, and not the released version?
I have now downloaded the linked version again and reinstalled it. I opened the database and first selected the Tag Explorer and then the tags within the mails -> All tags are now displayed correctly.
Thank you very much.
