On temporary LAN-interruption EPIM crashes.
- Has thanked: 15 times
- Been thanked: 3 times
I think EPIM (Windows) should be more tolerant to temporary LAN-interruptions. At the moment it is crashing in such situations. My LAN is stable, but I have also a VPN (Hamachi) running (realized as a 2nd, virtual network adapter), which has to be restarted or has to be interrupted for other reasons. Other software has no problems switching from one network adapter to another. Even copying big files in Windows may be interrupted for a few seconds, when I switch off the VPN, but then continues with no problem using the other, physical network adapter. Same is true for another database client (PostgreSQL). EPIM usually crashes in such situations, has to be killed with the task manager.
