[FIXED] Have To Enter Password Twice -- REGRESSION 11.2.4
- Has thanked: 4 times
- Been thanked: 14 times
Fixed in version 11.2.5
Reappeared in version 11.2.4
Fixed in version 8.1
EPIM Windows 8.01
1) Module Open: Passwords.
2) Minimize to taskbar
3) Restore
3) EPIM asks for Password after much less than 2 Hours (sometimes 5 Minutes)
4) After first (correct) entry of password shows Calender, asks for Password again and then - after (correct) entry - switches to Module Passwords
Tools - Options - Securty
Checked: Show all private items ...
Checked: Include private Items ...
Automatically lock when switching to another module: After 2 Hours
Checked: Passwords
Cheers,
Nurgotora
EPIM Windows 8.01
3) Restore
Checked: Passwords
Cheers,
Nurgotora
Re: [BUG] Have To Enter Password Twice
seems like it will be fixed in forthcoming 8.02
Yes, we need assistance in reproducing the issue (on 8.03 version). We were not able to reproduce and thus no chance to fix it. A video demonstrating the issue would be best.
I'll try.
The process is always the same and perfectly reproducable - except for the time elapsed between minimizing Epim to the taskbar and re-opening it: I am not sure, but think less than the two hours configured.
Epim 8.03
Windows 7 Pro 64bit
The password used for Database protection on PC is the same as used for module Passwords on the mobile device (Android)
Settings:
Steps to reproduce:
1) Switch to module Passwords.
... Wait ...
3) Restore
4) EPIM shows gray, empty window and asks for the password
5) After (correct) entry of the password shows module Calender and immediately
6) Asks for the password again
7) After (correct) entry - switches to module Passwords
Epim 8.03
Windows 7 Pro 64bit
Settings:
Steps to reproduce:
... Wait ...
3) Restore
Not a video, but screenshots:
1) Switched to module Passwords at 9:25
2) Minimized to taskbar at 9:26
3) Restored at 14:39
4) EPIM asks for the password (just the Dialog on the desktop) 5) After (correct) entry of the password shows module Calender and immediately
6) Asks for the password again 7) After (correct) entry - switches to module Passwords
Thanks. We will attempt to fix it in 8.1 Beta 2 which we are working on at the moment.
Re: [BUG] Have To Enter Password Twice -- REGRESSION 11.2.4
Thanks for the report, will address this problem in the next minor release of EPIM.
