Synchronisation with Windows Mobile 2003 on Anubis Typhoon MyGuide works properly if no database is loaded. You get to see all tasks, schedule times, however, the categories of the tasks and schedule times are not synchronized although they are only the default categories.
BUT: although the prog. says sync is ok there are no synched data if I load my old database!? I will keep on checking that ... I'm not sure if this is going to be reproducible ...
Furthermore, EPIM choked on my old database (1.6) first time I loaded it and I had to kill it via taskmanager.
Regards,
DBH
Sync with Win Mobile 2003 ok, but ...
- Has thanked: 1418 times
Synchronization of categories is in our To Do list, thanks.
