Bug since ~8.0: too long active link in internal links to an item
Trinitylab
Has thanked: 16 times
Been thanked: 41 times
Post by Trinitylab »
Win 8.1 and 10, x64, newest EPIM Pro Biz Net.
The problem persists since around 8.0, maybe a little bit earlier, but I am not sure, simply do not have time to describe all the bugs after each update.
Now it's time for the next.
See two screensaves, how cursor behaves:
1. correct, this is an old event, moved to another dates, the cursor in an event title area works like always, properly - changes into active "hand" when I hover directly over an active link to be clicked then:
EPIM_active link correct.png (2.09 KiB) Viewed 991 times
2. wrong, all the new events created after certain update which I do not recall, have it. Simply an active link takes almost all free space of an event title area in a calendar, and makes it much harder to catch an event and open or move it. Instead of opening an event, quite often, a click opens an item to which a link links :) which is in our case typically a contact record:
EPIM_problem_active link too long.png (1.75 KiB) Viewed 991 times
Please fix it, and make it working like before, that only hovering over the exact link changes a cursor and so on.
Unfortunately, I do not know why, a cursor was not screensaved in the above pics.
Best,
Piotr
