关于8.02专业版的一些问题
关于8.02专业版的一些问题
我在使用8.01专业版的时候,发现专业版的日历功能中,改变EPIM窗口的大小,每条任务的内容并不会自动根据内容的长度调节,而是内容超出了任务列表的范围,正常情况下应该自动换行显示,免费版中并没有遇到这个问题,我认为这是BUG,请修复。
- 内容不会完整显示,无法自动折行显示
- QQ截图20180820011423.png (2.37 KiB) Viewed 30714 times
Re: 关于8.02专业版的一些问题
there is no difference between EPIM Pro and Free in this regards, but your suggestion noted, thank you!
Re: 关于8.02专业版的一些问题
I just did the test. In the case of inputting Chinese, the Pro version will appear with the title not automatically folding. Free will not cause problems. Entering English letters does not have this problem.
- QQ图片20180820212046.png (4.61 KiB) Viewed 30708 times
Re: 关于8.02专业版的一些问题
Can you please post the Chinese text in subject, so that we could try to reproduce the issue.
Re: 关于8.02专业版的一些问题
You can enter the title and content box to enter:测试test测试test测试test测试test测试test测试test测试test测试test
. You will find that the content does not automatically display the next line.
This BUG will appear when you input Chinese.
- QQ截图20180906143125.png (4.13 KiB) Viewed 30691 times
Re: 关于8.02专业版的一些问题
thank you for a test message. However, can you give a more realistic example? String "测试test测试test测试test测试test测试test测试test测试test测试test" is not likely to be used anywhere in real life.
Re: 关于8.02专业版的一些问题
Regardless of any Chinese or English string, there is a problem with displaying the next line. You must add a space character to the string to automatically switch to the next line. You can try typing aaaaaaaaaaaaaaaaaaa. I don't think I will output a space character when I write the content, so I won't show the second line. I think this is unreasonable.
Re: 关于8.02专业版的一些问题
That's why I asked for a realistic example. "aaaaaaaaaaaaaaaaaa" does not happen in reality.whm630987633 wrote: ↑Tue Sep 18, 2018 9:34 amRegardless of any Chinese or English string, there is a problem with displaying the next line. You must add a space character to the string to automatically switch to the next line. You can try typing aaaaaaaaaaaaaaaaaaa. I don't think I will output a space character when I write the content, so I won't show the second line. I think this is unreasonable.
Re: 关于8.02专业版的一些问题
I have such a problem here. Do you need to use TeamViewer to view my computer remotely? Or a better way of contact?Max wrote: ↑Mon Sep 24, 2018 9:57 pmThat's why I asked for a realistic example. "aaaaaaaaaaaaaaaaaa" does not happen in reality.whm630987633 wrote: ↑Tue Sep 18, 2018 9:34 amRegardless of any Chinese or English string, there is a problem with displaying the next line. You must add a space character to the string to automatically switch to the next line. You can try typing aaaaaaaaaaaaaaaaaaa. I don't think I will output a space character when I write the content, so I won't show the second line. I think this is unreasonable.
- 企业微信截图_20180925102347.png (4.03 KiB) Viewed 30662 times
- Has thanked: 1412 times
Re: 关于8.02专业版的一些问题
No need, thanks. This will be improved in the upcoming 8.1 version of EPIM.
