How about being able to create a task template with multiple reminders?
right now if you create a template with multiple reminders, all but the first reminder disappears when using it again.
You can generate multiple reminders for a task, but if you need it for multiple tasks you are doing it repetitively each time. saving a template would avoid having to "create" (+) the reminder then adjust the date and time - potentially error prone process..
great product - thank you!
