Phone extensions of contact no longer sent to dialer
Lizzie
Has thanked: 8 times
Post by Lizzie »
I'm using EssentialPIM for Android 5.5.1, free version
the phone runs Android 6.0 (Moto G 3rd gen)
Before, when "tapping" the phone number of a contact in the Contact module of Epim, it would launch the dialer with the full phone number, including the extension (format 999-999-9999;1111). After dialing the number, the dialer would ask if it should dial the extension(1111), so I could ok it when appropriate according to the automated message.
I'm not sure if this began with this last update or the one before, but for some time now epim only sends the phone number (the 999-999-9999 part) without the extension to the dialer. :(
The dialer still recognizes extensions when I add the contact directly to the phone's contacts, so the problem is with Epim. I don't think I've changed any settings and the phone numbers were working before and have not been changed.
Please help, this is causing a lot of trouble.
Has thanked: 1411 times
Been thanked: 984 times
Re: Phone extensions of contact no longer sent to dialer
Do you enter the number into the phone field for a contact same way you described: 999-999-9999;1111?
Lizzie
Post by Lizzie »
Yes, the phone numbers were entered in format "999-999-9999;1111".
Like I said, it was working before.
I prefer " ; " so I can "ok" at the appropriate time. " , " doesn't work well with all automated messages (since it's only a pause) but after reading your question I got curious and tried with the "999-999-9999,1111" format. Unfortunately, same problem, the extension doesn't make it to the dialer.
Interesting, we are not able to reproduce the problem, as the extensions get transferred to the dialer without any problems on our side. Will double check this issue on a Moto phone and try to fix this in the next update.
Lizzie
Post by Lizzie »
The last update resolved the issue.
