BUG since 8.0: multiplied some custom fields in Contacts records
Trinitylab
Has thanked: 16 times
Been thanked: 41 times
Post by Trinitylab »
Win 8.1, Win 10, both x64
Since EPIM 8.0 update some custom fields have been multiplied:
I think removing this will be a problem, because if someone entered data in the new field, then deleting one of these twins will result in data loss.
That's very poor.
Re: BUG since 8.0: multiplied some custom fields in Contacts records
Thanks. It is virtually impossible to reproduce or fix the issue based on this screenshot. If you suspect it was done during database conversion when updated to 8.0 (please note, database was converted to 8.0 (not 8.01 or 8.02), then you can try to find the special backup made by EPIM before the conversion. It has "...convert..." in it's name. If you can send this database to us (you can also open it in your previous EPIM version and delete irrelevant data)- we could try to reproduce the issue...
Trinitylab
Hi Max,
We use two DBs, Main and Sales, so there is "convert" file for May 2nd this year, but only for Sales.
Looks like for Main there is none, we have highly advanced hd search tool, and it could not find anything.
Extra backup is created always when database is upgraded, I find it highly unlikely for backup to be created for one database and not the other.
Trinitylab
Max, I checked this several times, the tool is for servers admins, null. Also Windows tool shows no results.
Our Main DB has some problems, unsolved, though. Maybe it is one of them.
