Android EPIM cannot find EssentialPIM running on PC
psyprof2000
Post by psyprof2000 »
I have been syncing via the same Wi-Fi network for at least over a year. Recently the tablet (Samsung Tab S2) and Windows 7 Home Premium 64 bit system.
EPIM Android (5.5.1) is connected to the Wi-Fi network but does not "see" the PC running EPIM Pro (8.02). Anything I can try?
Thanks in advance for the help.
Re: Android EPIM cannot find EssentialPIM running on PC
Are you still able to sync by using the "Connect manually" option?
psyprof2000
I did not follow the directions correctly. I did a manual sync and it is working perfectly now.
Thank you for a great program, very good support, and a quick reply.
I am very happy with this program and was lost for awhile without it.
