How to synchronize a specific module
Currently, i am using google for sync. Each time i manual trigger sync via File->Synchronization->Google, it keep trying to check and sync all the different modules. Is it possible to manually sync just one particular module (e.g note), instead of everything.
- Has thanked: 820 times
Re: How to synchronize a specific module
please go to Tools-> Options-> Synchronization-> Google and select modules you want to synchronize.
Ok. Thanks. Just a suggestion, can consider allowing user to right click on the specific modules, and choose "Synchronize".
More convenient for user, instead of having to repeatedly go to Tools-> Options-> Synchronization-> Google and select different module to synchronize
so far we have not see a usercase where one would need to change modules often.
