SPANISH TRANSLATION
Has thanked: 1419 times
Re: SPANISH TRANSLATION
Thank you! Note, there's EPIM 7.2 Beta 1 version available, you might want to check it out ;)
jjeemm
Post by jjeemm »
I don't know if this is the best place to make this comment, but here I go...
Since some versions ago of EssentialPIM I have ever find the same mistake in the spanish translation, which I have solved by modifying the Spanish.lng file. Unfortunately, each upgrade makes me search again for this file and correct the error. It is a simple one, but generates some confusion when printing. I suggest to modify 3809 string as:
3809=Estilo Diario|Estilo Semanal|Estilo Agenda|Estilo Mensual|Estilo Anual|Estilo Tabla
Kind regards,
This will be included in the next version. Thanks!
