Hi all,
I have a problem after upgrading to version 7.6
Exception log with detailed tech info. Generated on 11/11/2017 17:16.
Application title: xxxxx.epim - EssentialPIM Pro Portable
Application file: C:\Users\xxxxx\Documents\EssentialPIM Pro\EssentialPIM.exe
Application: EssentialPIM Pro Portable 7.6 09/11/2017
Exception class: EAssertionFailed
Exception message: Pending and direct clearance are mutual exclusive! (D:\Components\VirtualTreeView5_\VirtualTrees.pas, line 24439).
Exception address: 007633A2
Main thread ID = 14904
Exception thread ID = 14904
Object Logs:
74669468 SetViewMode OK
74669390 SetViewMode 6
74284781 SetViewMode OK
74284437 SetViewMode 3
73958437 SetViewMode OK
73958312 SetViewMode 6
70698500 SetViewMode OK
70698343 SetViewMode 3
62053734 SetViewMode OK
62053578 SetViewMode 6
62051171 SetViewMode OK
62050968 SetViewMode 1
62048203 DBOpen OK
62048171 SetViewMode OK
62048015 SetViewMode 0
62031359 DBOpen
76110296 ExceptionDialog TextMemo
74675546 MainForm FormPan FormPan2 PasswordsForm ListsPan PassEntriesVT
74672046 MainForm FormPan FormPan2 PasswordsForm ListsPan GroupsVT
74669546 MainForm
74667546 MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC
74284828 MainForm
73961765 MainForm FormPan FormPan2 PasswordsForm ListsPan PassEntriesVT
73958765 MainForm
70698875 MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit
62612281 MainForm FormPan FormPan2 PasswordsForm ListsPan PassEntriesVT
Last Clicks:
74782171 TBXItemClick: MainForm FormPan TBXToolbar2 TopPan TopTB AutoTypeTBI
74688875 TBXItemClick: MainForm FormPan TBXToolbar2 TopPan TopTB AutoTypeTBI
74669625 MouseClick: MainForm LeftPan NavPanel NavGroup6
Memory: 16252; free 10916
Stats:
MouseClick: MainForm FormPan FormPan2 PasswordsForm ListsPan PassEntriesVT 7
MouseClick: MainForm LeftPan NavPanel NavGroup1 1
MouseClick: MainForm LeftPan NavPanel NavGroup3 2
MouseClick: MainForm LeftPan NavPanel NavGroup6 3
MouseClick: PasswordDialog PasswordEd 1
TBXItemClick: MainForm FormPan TBXToolbar2 TopPan TopTB AutoTypeTBI 2
TBXItemClick: MainForm Panel0 TopPan TBXToolbar1 HelpMI HelpWebsiteMI 1
Updates: 1
Last update: 10/11/2017
Module Password problem
Re: Module Password problem
can you post a video where you are reproducing the problem? That will help us reproduce the issue on our end and, consequently, fix it.
Hi Max,
thank you for your quick reply. As the problem does not occur each time I can not make a video of what I'm doing. In any case it simply happens when I click in the URL field of the password module to open the related link.
